Sintra
Ok i have a Chrysler Voyager which has recently had the abs light stay on.
Now i know by turning the ignition on and off a few times brings up the diagnostics codes of which i have 2.
No.1 P 0645
No.2 P 1685
One of these is probably to do with the AC relay being removed and the other is hopefully a faulty abs sensor.
Can anyone help out with these codes as to which wheel sensor if any is faulty.
I can understand the P 0645 code as i have a relay removed but unfortunately the P 1685 appears to be something to do with a skim key and not the abs.
Anyway thanks for your help guys.
Sintra,
Sintra,
