Hi
I am working on a project which requires me using a Xenon HID car headlight, however I need some advice as to what I need in order to use this on a mains plug (UK).
I have a power supply: 12V 10A Power Supply,120W Power Adapter 100-240V AC to: Amazon.co.uk: Electronics
(https://www.amazon.co.uk/Adapter-100-240V-120Watt-Transformer-Monitors-Black/dp/B08K4BGKM3)
And this is the bulb I have found: D2S Xenon Bulbs 6000K White 35W HID Headlight Direct Replacement 12V Car Headlamp Bulbs (Pack of 2): Amazon.co.uk: Car & Motorbike
(https://www.amazon.co.uk/Xenon-Headlight-Direct-Replacement-Headlamp/dp/B08DHSS22W/)
But need to know what needs to go between the power supply and the bulb. If someone could advise please I would be grateful.
Steve
As an Amazon Associate we earn from qualifying purchases.
you connect the output of the PSU direct to the xenon bulb. an in line fuse might be advisable.
A xenon headlamp needs an ECG (electronic control gear, aka ballast) to convert the 12V DC into high frequency AC. Some types also need a separate ignitor that connects between the ECG and the lamp.
There are four popular 'standard' types of lamp that are not model-specific. All are 35W but have different requirements for ECG and ignitor:
D1: 85V ECG, integral ignitor.
D2: 85V ECG, requires separate ignitor.
D3: 42V ECG, integral ignitor.
D4: 42V ECG, requires separate ignitor.
Then for each of these types there are two versions, suffix 'S' is designed for projector optics and has a completely clear envelope, suffix 'R' is designed for a reflector and has part of the envelope masked to control glare.
Your link is to a D2S lamp. This therefore needs an 85V 35W ECG and an ignitor.
Car headlight (HID Xenon) on UK mains plug?
steve pike,
pc1966,
