Discuss Ceiling Light Issues in the DIY Electrical Advice area at ElectriciansForums.net
Mozlawolf
I stupidly failed to take a picture of the original wiring and only realised afterwards that I had four earth cables and 4 black cables going to the older light fitting. The red wires were all in a connector block and tucked away in plasterboard. How do I determine what each black wire is to go to a Live and Nuetral light fitting?
Can you show a pic although without a continuity tester it may not be possible to guide you from afar.
Red sleeves indicating ya switched lines or test gear mate I’m afraid, any pics?
bloody hell youre quick @westward ?
Please see the attached picture! Thanks for the quick reply - I also have a multimeter. The four black wires were attached to the old light fitting and the red wires were in a connector block stuffed into the ceiling. I tried to send a brown wire from the red connector block to the live terminal on my new light fitting and a blue wire from the black wires and the light came on (when light switch was off) - when I flipped the switch this tripped the lighting circuit.
Only three of the blacks are neutral the other is the live return from the switch. You should have continuity between the reds at the connector when the switch is on and one of the blacks only, that is your live.
Thanks really appreciate this! What setting on Ohms should I set my multimeter to? Do I connect the black multimeter clip to one of the black wires and then the red one to the corresponding red wire? What should I look for on the multimeter screen - will the number go high on the switched live cable?
Put it on 200 ohm. Leave reds all connected together and test each black to the reds until you get continuity. Get someone to turn the switch on and off and you will get a reading when on. Only one will do this and it doesn't matter which way the meter leads go but ensure POWER IS OFF.
Good news - finally sorted it! The black wire that changed its value when the light was in on position was the live switch wire and the others in neutral worked perfectly! Thank you so much for everyone’s help!
Good work!...put a red sleeve on it for the next poor sod! ?
Reply to Ceiling Light Issues in the DIY Electrical Advice area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
Hi, I need some advice on the wiring for a new ceiling light. I have taken down the original light, and I'm left with the wiring in the image...
I am adding a light fixture in a room I am restoring in my 160 yo house. I have ran a new 12-2 w/ground wire from the ceiling box to a junction...
