Search the forum,
Discuss Ceiling light troubleshoot in the DIY Electrical Advice area at ElectriciansForums.net
Hi all. Any help/advice regarding my rewiring would be appreciated. I'm very likely calling in an electrician once we're allowed to, to sort out my mess.
I wanted to replace pendant lights in my Kitchen. There are two lights connected to the same switch.
The original wiring was like so:
And the box for the new lamp was like so:
Blue wire on the left hand side, brown to the right.
My handy work was this:
And astonishingly enough, when I turned the power back on and switched the switch, both lights came on! Hurray. But then when I popped everything on, the 2nd light didn't come on:
So I'm thinking a wire came loose as I was fitting the bracket on. No problem, let's have a look, and sure enough, it looked like one of the neutral wires were loose. Okay, so redid them and now nothing turns on! D'oh.
Any clues as to where I buggered it up?
Those connectors are not suitable for multiple cables and what you have done demonstrates this. That is an accident waiting to happen, I would recommend an electrician to connect it safely.
Thanks Westward. I'll keep them off until I get an electrician in.
What type of accident are we talking about with using this connector? Fire?
Lose wires can cause fires do not take the chance. Good decision getting a professional in.
Reply to Ceiling light troubleshoot in the DIY Electrical Advice area at ElectriciansForums.net
Good Morning need some advice please. Yesterday went to change a light fitting in hallway. There are two ceiling lights in the hall controlled by...
Hi, there are 3 bundles of wires coming from my ceiling and I've been told they have been tested with a multimeter and have all got a current but...
I am adding a light fixture in a room I am restoring in my 160 yo house. I have ran a new 12-2 w/ground wire from the ceiling box to a junction...
Hi, I need some advice on the wiring for a new ceiling light. I have taken down the original light, and I'm left with the wiring in the image...
