Discuss Ceiling Rose Fitment in the Australia area at ElectriciansForums.net
P
pOrmsby
Hi, This is my first post so if this is not the right place please let me know.
I am looking at wiring a lamp holder (screw in bulb fitting ES27 type) to a cable and socket for use on a ring main. (ie, I am making my own lead lamp with a length of cable and a normal socket on the end.)
I guess its a basic lamp setup.
Are there any foreseable problems in doing this?
Many thanks for any suggestions.
Peter
Use a flexible cable,with a 13a plug fused at 3a,if the lampholder is ES make sure you connect the live (brown) core to the centre contact of the lampholder.
Edit....sorry re-read your post and not sure if you are planning to plug it in to a socket on the ring main or to a lampholder on a ceiling rose??
Make sure you use a proper extension lead socket to plug your lamp into. Or if you have a spare metal glad socket and metal glad box, make sure you gland the flex into it.
Reply to Ceiling Rose Fitment in the Australia area at ElectriciansForums.net
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
A rose in my 1970s kitchen ceiling became loose (one fixing screw had been inserted right on the edge of the hole in the ceiling) and when I...
