Discuss change a corded switch to a NEON corded switch in the UK Electrical Forum area at ElectriciansForums.net
J
johnst
In a bathroom I have a non neon corded switch which operates extractor fan.
I would like to change this to a NEON corded switch in bathroom.
Is this a job for a qualified electrician or is it a straightforward job for DIYer?
Changing a light switch is straight forward, but there are many ways to go horribly wrong. Bathrooms are considered a special location due to increased risks from electricity and so for your safety, I would recommend an electrician. While they are there you might ask them to take a look at any other things you may need. All the best, David.
Neon corded light switches aren't the easiest to get hold of. I have a stash of crabtree retractive pull cord switches which I connect between fan l and fan switched l which activates the fan for the pre-set time period (usually between 1-20 mins). Being retractive switches the fan cannot be left on accidentally.
As others have stated, safest to get an electrician in to advise and sort
In my opinion, the sole fact you have to come and ask if you can do it, to me means you probably shouldn't. It could end up costing you a lot more if you try and it goes wrong, and i don't just mean money. Surely its worth paying up to £50 to have it done properly?
another consideration is that there's probability of there not being a Neutral at the switch, in which case the neon will not work.
Reply to change a corded switch to a NEON corded switch in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Just a quick one, I want to use an ip rated light switch with a neon indicator to manually ovveride a PIR detector controlling an e27 LED...
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
Hi, I'm a hobbyist without formal training. I'm looking to power audio/video equipment over several hundred feet of extension cords. I have 2...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
i have a toilet compartment and a separate adjacent shower room and i am fitting one remote extract fan, via a Y splitter to ventilate both rooms...
