Discuss Change Power Tools in the Electrical Tools and Products area at ElectriciansForums.net
Walls made out of what is the question?
Depends what your using it for, m12 kit is brilliant and lightweight but if your needing any bugger than 8 or 10mm hole you'll need the m18. I have both and if I was to only have 1 I'd have the 18v kit it covers everything you'll need although the sds is considerably heavier.
It is heavy to be carrying around especially when working off ladders and stuff the m12 sds is very handy for thatThanks, most of what I do Alarms and CCTV rarely need anything bigger than 10mm as the cables are not that thick. The only issue I found when I had my Milwaukee 18v SDS none Fuel was that it was really heavy and too big for general day to day work. It only helped when doing Fire Alarms which we don’t do much of. Plus the odd occasion you need to do 20mm holes.
An idea I have thought of is go with the 18v kit, I’m not sure if that one I have posted is the latest or the best model etc. Then buy a 12v SDS for the smaller jobs.
First time I have seen predictive text change to something that funny, or was it.Depends what your using it for, m12 kit is brilliant and lightweight but if your needing any bugger than 8 or 10mm hole you'll need the m18.
Reply to Change Power Tools in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
