sometimes it's the simple things. her indoors has a renault ( not a van) and the heater would only blow cold, feebly. turns out , hidden below the dash , was a pollen filter., clogged up. main dealer recommends changing every 2 years. at £30+vat, dustbin, no filter now, works a treat.
lol.....!! i had similar problem on a nuke sub i worked on!! kept loosing sucking on a bilge pump! strainer kept getting clogged! removed strainer and worked a dream...! did have to replace the pump bowl on a bilge pump not long after as the pump broke!! may be a coincidence!! may be not! made my job easy at sea and the new pump was paid for by navy so i was not bothered!
That post scares me. Making bits of a nuclear sub redundant and throwing them away at a whim doesn't sit well. Maybe I'm just old fashioned but I prefer the thought of nuclear subs being as per manufacturers specs :-)
unfortunately a sub aged 25 years was FAR from the original Manufactures Spec!! hahaha...!
the Platform i served on in its lifetime had struck the bottom of the ocean, stuck various items at sea and in river, had a major switchboard fire, had a nuclear radiation leak and was leaking water..!
you be amazed what goes on to keep a vessel at sea!
The astute is only 2 months old and there already making systems redundant, the parking sensors where the first thing to get axed ;)
hahaha, they suffered a steering gear failure! CLASSIC! p.s "ASTUTE" is actually "AMBUSH" as due to the delay on Astute Ambush over took her in build! so they renamed her! lol
Steering gear failure nice that explains everything..... brilliant :D The tug boat actually caused more damage to her, than the running aground. There coming up with some pretty good names for the new boats.
How the heck did we end up on submarines from Citroen MPG??? :D
I loved my Berlingo.
I drove it like i stole it :D
Type T120 connect hunter killer. forward loading tube carriers x2, active Tom Tom one navigation and I drive it like an old Lady. Thread back on track ;)
think it went from a follow up of bodging a job to fix it!!
yeah some of the names are cool..! I served on HMS Turbulent, and the new boats, AMBUSH, Audacious and Artful are pretty good..!
i still like HMS Vengeance .... its sounds really menacing and strong!
I feel a bit inadequate, I don't have a van for work.....or sub for that matter.
I had a similar problem with wifeys Renault Scenic 1.9 DCI, fuel comsumption went through the roof and it ran a little lumpy, even cut out once or twice after we ignored the symptoms for a few months. Turned out to be a sensor of some sort on the exhaust. Can't remember the name of the damn thing but it was three letters. It sits in a little housing which got packed full of soot, the mechanic removed it, brushed and scraped it out and refitted it. Took about an hour and all's bin well ever since.
Nearly all recent diesels have them.
I think its something to do with helping the engines comply with the EuroIV emissions thingy.
Amp David,
Marvo,
