Discuss Clear chandelier wires in the Commercial Electrical Advice area at ElectriciansForums.net
Reply to Clear chandelier wires in the Commercial Electrical Advice area at ElectriciansForums.net
Hi guys. I will start by apologizing for the elementary question. I'm sure you get them often. The chandelier is in a hallway controlled by a...
Hello, We changed plans with lighting in one zone. Now instead of 4 downlights (square shape of 1400mm side) we want a chandelier. Since...
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the...
Hello, I am currently learning and have come across PAT testing an old chandelier. On modern lamps I would use the plug and probe on the...
I have a new 15 arm chandelier, each arm has 2 lights which use G9 LED bulbs (3W equivalent). Each arm also has four wires coming into the base...
