Search for tools and product advice,
Discuss Click UK switch fuse in the UK Electrical Forum area at ElectriciansForums.net
newfutile
Supporter
How would others code the switch fuse not meeting IP4X on the top surface?
The live terminals are very close to the top edge
It's in a communal cupboard what if someone put there car keys there while checking the meter? Is silicon conductive before it dries.
ip4x is a 1mm piece of wire,ip2x refers to a bs finger
These kind of nibble outs have always naff and normally nearly always leave a gap around the cable entry. Most sparks will squidge a bunch of mastic around the gaps but it still looks rubbish
Or decided to take their metal knitting needles in there. I was trying to make a sensible risk assessment.
Silicone is not conductive snd - in any case - why touch it while it’s wet?
But we are now talking about resolution of the issue. I thought you were doing an EICR?
You can see the terminals from the top, in any case work has asked me to address the issue,so I spilt some 16mm blind grommets with a bit of ct1 to keep in place
Reply to Click UK switch fuse in the UK Electrical Forum area at ElectriciansForums.net
Electrical2Go - A Guide to Click Sockets: Which Is Right For You? Click Sockets Guide: Which is right for you? Click is a leading manufacturer...
Hi everyone, just wanted to ask if any other sparks who use scolmore click mode have recently noticed a drop in the quality of their accessories...
Hi, I have recently bought a house and I have a fused switch in my living room which I don't know what it's for. I believe it was a switch for a...
Hi we have been asked to run a 3 phase supply into a boiler house to feed a DB fed from next to the existing meter. Would we need to install Tails...
Hi I have a customer who has a kiosk with 100 amp cut out fuse supplied from UK power, he needs to bring the power 178 meters to his house, He...
