I am a retired electrician and have been out of the game for 10+ years but I now have to do some work on my campervan which has the requirement for double pole devices. Back in the day I would of happily used a two module RCD followed by a two module double pole MCB. However nowadays there appear to be plenty of compact, single module, double pole RCBOs available which look ideal given I am short of space. However then I started down a bit of a rabbit hole as I noticed they can either be marketed as double pole or 1P+N. If it was a MCB I can see the difference, double pole needs overload/fault detection on both Line and Neutral. However with say the MK H7732M, which is marketed as double pole, it looks like overload protection is only on the line (with RCD on both). Then the FuseBox RTAMB16B0 is marketed as 1P+N but appears to be the same configuration, ie overload detection on L but also switches the neutral.
Logically I cannot see why it would need neutral overload detection on an RCBO as L-E and N-E faults would trip on earth leakage and L-N overload on L overload detection.
Am I missing something, are these two devices actually the same and both meet the double pole requirement?
https://www.screwfix.com/p/mk-sentr...e-b-curve-bi-directional-miniature-rcbo/341ye
16A 30mA RCBO - Fusebox 6kA (Type A) B Curve (Compact) - Bi-directional | Fusebox (RTAMB16BD) - https://www.tlc-direct.co.uk/Products/FBRTAMB16BD.html?source=froogle&srsltid=AfmBOoq1xawJj1h-N9lWEU7cZiYSo1gRB6Kz13wQZkasz8y1JWCdumgwZM4
