Discuss Computer memory. RAM....... in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Spoon
Mentor
In the past I was told that for RAM it was better to have 2 memory cards rather than one.
e.g. have two 4GB cards rather than an 8GB card.
Is this still the case?
It depends weather or not the motherboard supports 'duel channel'. And also you need to use to identical chips. Ideally a pair sold together for the purpose.
Just looking at getting a new comp. Seeing if the old rule of "2 memory cards are better than one" still applies.
Will have to check out the motherboard.
Ta mate.
From memory, pardon the pun, Dual channel is slightly faster but needs a matched pair and a motherboard that supports it.
If you plan to upgrade ram in the future you are limited to replacing with 2 bigger sticks rather than adding 1 or 2 more.
For the SSD I have a 960 Evo M.2 and it is like Shyte off a shiny shovel.
Possibly there are newer cheaper options on the market now though. :)
With modern PC's you won't notice the difference unless you are loading the memory heavily with applications, playing Tetris or Solitaire will be fine but as mentioned a decent SSD drive makes a hell of a difference.
Are you looking for a laptop or a desktop?
What are you planning to use the PC for?
Playing games and editing video's for my daughters YouTube channel.
Rendering videos takes about 2.5 hours for a 30 min vid. If she does an hour vid then it takes lots of hours and I end up leaving it running overnight.
All mainstream desktop motherboards these days use dual channel memory...the 'HEDT' ones are even quad channel. Dual channel memory will be worth it for gaming and video editing, can make a significant difference. If a new PC didn't have it these days, I'd be wondering what other corners have been cut.
Reply to Computer memory. RAM....... in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
Hi guys and gals, I have a question about the leads to computers (commonly known as kettle leads). I am new to PAT testing so please bear with...
Morning all, We are looking at qualification requirements for inspection and testing to BS EN 60204, all of our work is past the main isolator of...
Hi all, adult learner retraining and sorry if this is in the wrong place but I need help. my provider are being very cards against their chest...
Hey guys. So, I'm building a lower consumption pc for a pfsense router. The build is done, tested it last night, went through some configuring and...
