Discuss Comsumer unit in the Australia area at ElectriciansForums.net
R
RJB
Hi
I am about to fit a new consumer unit, i plan to install a split loader one side for power i.e ring,cooker protected by a rcd the other side however i plan to run the lighting straight from the main isolater switch protected by rcbos, will that be ok to do?? plz help
how many lighting circuits - division of installation should be taken into consideration, partp and full set of testing required also.
pretty much all circuits require additional protection via .30ma
can't see any problems there, but as ezzzekiel says, test cert and part pee
Ok there are eight circuits: 3x rings (1 kitchen) all 32a, 1x cooker 45a, 1x heating 16a, 3x lighting 6a and 2 spares??
i wouldn't put all 3 rings on 1 RCD .a fault on one ring tripping the \RCD will take out all sockets. instead of rcbo's i would fit dual rcd board with rings split between the 2 and also the lights. i try and split the kitchen ring and it's nearest other ring so un the event of the kitchen ring being down, a temp. supply can be run via extn.lead from next room to power the fridge/freezer. and vice versa, for the TV. as long as the freezer and terlly work, anybody can wait for the fault to be fixed.
other option for not much more money is a split load high integrity board ......Split the rings, 2 on 1 side with the heating, then on the other 1 ring with the cooker then put your 3 lighting circuits on RCBOs. OR you could just put in a little 8b way board all rcbo, I like these and favour this option!
dual split load board, with 2 spare non rcd ways so RCBO's can be installed at a later date for things like smoke alarms or a dedicated fridge/freezer socket. Segregate circuits to minimise inconvenience in case of a fault, i.e, upstairs lights and downstairs sockets on one RCD and down lights/up sockets on other etc etc.
Cheers..........Howard
Reply to Comsumer unit in the Australia area at ElectriciansForums.net
Hi everyone, I wondered if anyone could help me with something that has been niggling me please?! When a Solar PV feed in circuit is installed...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
Hi all, Grateful for your expertise regarding my confusion on the below. Context: French rural domestic property Single phase supply, TT...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
