Steve T
Hi all,
I'm almost finished doing a kitchen and I'm at appliance stage now, back when the kitchen was rewired the spec said it was a 2.3kw oven that required a 13a fuse and a 5.6kw hob, so the sparky has ran in a 6mm feed as normal and put a Stanic duo outlet behind where the oven will be, quite a new product I understand but seems like a good idea since so many ovens nowadays state they want a 13a fuse.
Unfortunately upon unpacking the Lamona oven I've got it has a label on the 1.5mm flex that says 'do not fit plug'. However the manual still states it wants a 13a fuse - although it doesn't actually specify how this should be achieved, so one might assume they want you to use a FCU??
Obviously doing that would create extra work having to swap the double back box for two singles and in my mind I can't really see how a 13a fcu is any better than a 13a plug?!?! I mean they're both pretty much equally likely to overheat. Just wondering what you guys would do, either ignore the label and just fit a good quality plug or mess around changing the backbox and put in an FCU? Or something else?
Cheers
If there is clearance for a plug? I can't think of any reason not to have a plug, maybe ask the manufacturers why a plug is not suitable.
Is it still 2300 watts or about 10 amps
Hi, yes there's enough clearance the plug would only come out about as far as the hardwired connection point on the stanic outlet, and the oven is definitely rated at 2.3kw and asks for 13A fusing in the manual, just doesn't specify how this should be done. Also I can't see anywhere in the actual manual stating to not fit a plug just a label on the flex! I will check with howdens, perhaps this is just a standard label they stick on all cooking appliance flex's as the lamona hob (5.6kw) also has a label on the flex saying this!
