Aye laddie, steer well clear of that dodgy Geordie crowd that hangs around these forums!
think id be more inclined to use wago's or din rail mount connectors so much easier , the quality of terminal block is so poor these days I wouldn't trust it
I reckon he didn't like the look of them and was just using the fault current thing as a way of pulling the wool as it sounds more technical than 'I don't like choc block in panels'. Which, to be fair, I don't like either, but there's no excuse for him to be spouting nonsense. There is a possible issue with poor quality terminals on low impedance circuits, that the screws can partially cut through the conductor and then in the event of a short circuit it fuses off at that point. But that is not to do with it being chock block as such.
Sounds like the insurance company once had a payout on a fire caused by a badly terminated strip connector, and now has a blanket ban on those "potentially costly" little blighters.
this stems from a electrical insurance inspection by royal and sun aliance where the inspector has said all connector blocks should be removed as they would not survive any potential fault currents
There's lots of reasons to dislike choc blocks as already pointed out they're inconsistent in quality and there's a bit of artwork in knowing how to fit them correctly and how tight to make them but condemning them on not being able to handle fault currents is a reason wouldn't fly. Bottom line is they're within the regs so unless you're working to an agreed spec that outlawed them from the get go then he doesn't really have a leg to stand on.
In a case like this I'd point out that your design meets the regulations therefore his request is seen as a preference which you're happy to accommodate at a fair price. Give him a quote for replacing all the connectors and leave the ball in his court.
So, if I have read this right (and I have to admit I skipped through a bit of it)... If the man from the insurance company is correct, we all need to be ditching our JB's, WAGOs etc and start using Henley blocks everywhere..... And 25mm singles? (Don't quote me on that, it was a guess)...
Where would it end? My lovely downlights I installed today would be a right mess with Henleys attached to them!!!!!
Where would it end? My lovely downlights I installed today would be a right mess with Henleys attached to them!!!!![/QUOTE]
They'd be in a bigger mess with 24,000 amp fault current running through them lol...............slight exaggeration I know:)
i think its his pet hate, but what ever he writes in his report i have to justify i writing not acting on the issues that he reports.
he doesnt have an issue with DIN rail connectors and the like, but u cant accommodate these in factory built start/stop motor control units
Then write something to the effect of "these connection blocks pose no danger under a programme of proper maintenance and inspection, and the report needs to be backed up by technical documents as you doubt the validity of it's claims"
thanks andy, sounds like thats the route i need to take.
As people above have already said, the PFC is more to do with the breaking capacity of the protective device and as connectors don't make and break circuits then they wont have a rating.
When an MCB Fuse or any circuit protective device breaks an arc develops. The breaking capacity (normally in kA) is there to tell us that the device under fault conditions is capable of containing this arc.
Ah, but then there is the bracing capacity to consider, which also has a KA rating, which has nothing to do with the overcurrent devices!! lol!!
Back to the op, so when using these nice connector blocks, are they enclosed? covered in tape? or open?
