Discuss Consumer unit cange in the UK Electrical Forum area at ElectriciansForums.net
H
hutch6447
Just quick one extending cables for new consumer board, gonna crimp extensions were needed now if crimps are inside unit then ok but if outside because customer wants different position then the crimps will have to go in a fixed box and be encased before it hits consumer unit. Thanks Matt
Hi all,
What if cables that need jointing come into the back of the CU from a cavity between house and garage. Can the cables be crimp extended and crimped section be left in wall behind CU?.
Also what heat shrink do you all use! Where are you getting it?.
Thanks in advance.
Yes the cables can be left in the wall after being crimped. Heat shrink can be got from any wholeseller for a few quid.
Even if you crimp using insulated crimps it's always better to heat shrink the whole cable before putting in the wall purely to waterproof it and stop water ingress.
Reply to Consumer unit cange in the UK Electrical Forum area at ElectriciansForums.net
Hi guys I am looking to add 4 additional sockets for a room that is being converted for a bed ridden person. The room at present has no sockets in...
I had a consumer unit replacement today. It was a bit of a nightmare as most of the cables were too short for the new unit. I extended the ones...
5K
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
