I recently quoted work for a guy which included a new consumer unit (TNS), and then noted that his summerhouse (about 40' from the house) and garage (a further 20' from the summerhouse) didn't have consumer units in them (Both had sockets and lights in them), so I made him aware that they both required seperate consumers units.
The chap (potential customer) emailed me to say that the other company who quoted him said that neither the detached garage or detached summerhouse required consumer units as they would be RCD protected at the house RCD. He even gave me the details of the company (who are also NICEIC registered).
I never try to sell unnecessary work to anyone, but both outbuildings are detached and both have light circuits and socket circuits and unless I am losing the plot due to the hot weather or old age (possibly both), they both require their own consumer units, or should I put myself on a basics training course?
From my point of view they dont need there own CU.. all depends on how you wire it, could get away with isolator in the buildings, then a fcu off the sockets for the lights. Have a read of this.
PME aside, if you take a circuit from existing house cu for sockets, then fcu off that for the lights. its no different to running sockets upto the loft and using a fcu to put a light up there.
Without seeing the install my self i cant be sure but i would say that they dont need there own consumer unit at all.
They are just long radial circuits from the consumer unit in the house, so long as the circuits are installed correctly there is no requirement for additional levels of non discriminated circuit protection along the length of a final circuit.
Why would they need isolators in the buildings.
No harm in having extra local isolation, saves walking to the house...look at Triton...they insist on local isolation so their engineers dont have to move their feet !!
To what end it is pointless. If you are going to suggest options to a client they should be required.
Really what you need to achieve is unnecessary tripping of the house .....
Separate CU’s isn’t necessary
Thanks for the replies much appreciated. I used to run outbuilding circuits off the non rcd side of the house consumer unit and have a garage 2 way board with rcd in the outbuilding, but an assessor informed me that this wasn't acceptable and both had to have rcd protection (which of course causes problems).
Dont think an assesor is always right, you can challenge them and ask them where they have got that nugget of male bovine excrement from in BS7671.
Which scheme?
Which regs did he quote?
