B
brightlight
I am pricing up a garage installation and the house cu has a split load with one rcd side and the other been a main. Would this need to be upgraded to duel rcd under 17 th regulations if i was only intending to come off spare way on rcd side to metal clad db using 4mm 3core swa? thank you for your help.
) as this provides the necessary mechanical protection when running the cable in a concealed fashion, i.e. through the wall.
