B
Buzz-light-bulb
Hi all
Just a quick one for you all, I did a eicr the other day and the consumer unit slightly over hangs the cooker space by 2" and is about 2 foot above the cooker space there's no signs of any thermal damage, I issued it a code 3 as its been in there a number of years and there's no damage at all, what code would you all issue
If its 2 inches over a cooker then I would issue a code C2 potentially dangerous ,reason is steam , heat etc , there is a potential there unless its IP rated mind
As above,its not just obvious signs of damage such as heat marks,steam could do a lot of damage that would not be immediately obvious.
It's been like that for 6 years ish, and I over exaggerated by 2 " it's more like 20 mm
i would think that kevin the kitchen fitter has stupidly designed the kitchen without considering the CU position. as previous posts, it's steam and condensation that's your enemy. MCBs and RCDs don't like getting damp. i'd have a gander inside the CU and see if there's any signs of oxidation. if the lady of the house is a lazy mare and only cooks once a week, you might get away with it, but i'd vacillate between a code C3 and a C2.
If it's been there for years then that's a lot of steam that's made its way into the mcbs. Who knows if there is any corrosion internally? Daz
