I have been going over this for some time, and every time I think I have it sorted I read something else which sows doubt in my mind again!
TT system.
CU to be replaced and moved to new location as not enough room where currently sited.
New location will result in tails being approx 5m in length and running short distance under floorboards.
Current set up would be DNO Fuse > Meter > DP Isolator > CU with 100mA TD RCD and 2 x 30mA RCD.
To reach new location I had planned DNO Fuse > Meter > DP Isolator > Switch Fuse > 25mm SWA > CU with 100mA TD RCD and 2 x 30mA RCD.
Do I need up front RCD protection of these "extended tails"?
I have read 522.6.204 (iv) to mean it is not required.
Would appreciate thoughts of those wiser than myself to stop me going round in circles.
Timotei
TT system.
Timotei
regarding the regs and installation safety.
