Discuss Consumers tails in the Australia area at ElectriciansForums.net
P
Peter Woodford
My mate wants his consumer unit changed in his flat but when looking at the consumers tails it looks as if it's been run in 10mm do I need to change this as it goes to a room in the basement and will be a pain to run new cables in. all he has in the flat is the following
One lighting circuit 6amp
One ring circuit 32amp
One cooker cicuit which at present is 40amp but will be changing to 16amp as has just got a 2.3kw cooker
One 16amp circuit for boiler
Cheers
peter will check the big red book and get back to you soon
Reply to Consumers tails in the Australia area at ElectriciansForums.net
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
Hi, I'm interested in a house built around the 1980's in Northern Ireland. I took a few photos of the consumer unit etc. which is situated in the...
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
