Discuss Contactor query in the UK Electrical Forum area at ElectriciansForums.net
mhar
Don't come accross these that often but today I have one that is buzzing a bit and is warm (compared to it's neighbouring mcb's) but not hot. It appears as though it is the control input that is causing the noise and heat as I am able to turn the loads off. It is a Hagar ES240.
Does this need to be replaced or is it fairly normal for a 10 year old unit?
Yeh as LeeH the faces get dirty on the laminated electro magnet and causes "chattering". I have cleaned them with VERY fine wet and dry, noise disappears.
I think the ES240 is one of those sealed type contactors in which case you won't be able to strip it and clean it. If it's noisy, check the voltage across the coil that's operating it is within the required range, if it is I'd suggest your only option will be dump it and replace.
Reply to Contactor query in the UK Electrical Forum area at ElectriciansForums.net
Hello All I was hoping for some advice. We have a microwave and recently after cleaning, as soon as the microwave was plugged in, a loud humming...
I'm looking at a German made roller conveyor system 10 motors contactors controlled by a PLC Issue is customer says 3 mths ago motors started...
hi all, Recently I have moved into a house which has a fairly old fuse box (no RCD) which I have planned on upgrading sometime next year. The...
6K
Squid
V
And the importance of being able to read them. This is a subject that really concerns me with the apprentices where I work and the management...
13K
cranedude
C
