Discuss Controlling my excess solar power in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
hello, I would like to get some advice on controlling my solar PV System. I have an 8.4kw solar array feeding into a Tesla powerwall 2. I also have a solar iboost to heat water in a hot water tank. I want to be able to fit a device to control the hot water heating using the powerwall when there is still above a given percentage of battery left and this needs to be smart phone driven so that I can change the heating times easily. I work random shifts so I need to vary the heating program weekly so I have hot water when I need it. If the battery is not charged enough then I want to go back to oil fired boiler heating. Is this possible?
Reply to Controlling my excess solar power in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi, I have a 6kw PV with a 6kw Growatt battery and invertor. I have a solar iboost going to the hotwater tank. Recently I had a Ohme Home Pro...
We have a 5.5kW incoming supply, which cannot practicably be upgraded due to our remote location in the mountains. Can I use a PV array and...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi all doing a high end new build and client has solar and battery storage going in (done by others for mcs grant ) I was talking to plumber about...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
