Discuss converting to a tt system in the Industrial Electricians' Talk area at ElectriciansForums.net
davino
Have to convert a tncs system to a tt systm,, knock an earth rod in etc...
anyone have any tips on a good install ? dont want to spend an hr bangin it in to find i dont have a good earth!!
Might be a dumb question, why do you have to convert it.?
Reply to converting to a tt system in the Industrial Electricians' Talk area at ElectriciansForums.net
Need some advice, I have 7 static caravans to connect which need to be connected via TT 1. All the vans have a 30ma RCD main switch internally...
Carrying out a EICR in a commercial setting. In the main intake room the DNO supply comes in and it states clearly this is a PME system. 5 years...
Now Ive done Periodic Inspection and Initial Virification Qualifications with LCL/EAL (so non C&G 2394/95) # strange part building Modules , this...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
