Discuss Cooker circuit tripping out with no appliances on it. Not immediately tripping. in the DIY Electrical Advice area at ElectriciansForums.net
Even if the cooker and the plug is turned off it still trips after about an hour. It doesn't immediately trip out but it usually always turns back off after an hour or two, it doesn't immediately trip out. Do you think I need a new plug? Can a device plugged into another circuit trip a different circuit? This has started happening after plugging in a new boiler, but the boiler doesn't turn off its on a different circuit, only the cooker trips. Could it be the plug to the cooker or what? Thank you.
You haven't provided nearly enough details for us to give a definitive explanation of what's happening, but yes, it is very possible for a fault on one circuit to trip a completely different circuit on most fuse boxes. These are neutral to earth faults.
Reply to Cooker circuit tripping out with no appliances on it. Not immediately tripping. in the DIY Electrical Advice area at ElectriciansForums.net
Hi I am asking for help as a novice and 1st time user of this forum. Recently started to experience tripping of MCB & sometimes with the RCD at...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
I'm not an electrician. I clean cookers and today arrived to a rangemaster range cooker. Got started, and as part of my routine, I turn on ovens...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
We have one room that seems to have lost most of its power last night. One of the outlets in the rooms has a power strip plugged in that powers...
