Discuss Cooker Extractor Plug or not in the UK Electrical Forum area at ElectriciansForums.net
Deleted member 112675
HI
I'd originally planned to have an mk grid switch located just above the worktop with four modules and each module a DP switch to isolate fridge, cooker fan, dishwasher and washing machine. Each switch would feed a spur to a single socket for each of those appliances. This is on the kitchen ring main. EAch appliance could thus be isolated and is fused by their respective plugs. I think/hope so far so good?
Then comes the issue which is the cooker hood plug socket location. I suppose I could try to hide it behing the hood or something like that but it doesn't seem very elegant or accessible. lI was thinking it might be better to chop the plug off and route the flex down to worktop level back to the DP switch but then it would only be protected by the 32a MCB.
The grid switch has 4 modules and they are all used (and sadly purchased). I haven't bought the extractor yet.
Any thoughts or advice most gratefully received.
HI
You don't need any of this, it is just the latest fad. Four items all at one place on the ring is not good practice either.
Put the cooker hood socket near the hood or perhaps in an adjacent wall cupboard.
I heard this stated on many threads, so not singling you out. In a typical domestic property, I see no reason why 'white' kitchen appliances can't be fed of RFC, e.g. ground floor one etc. In most installs, a fridge/fridge freezer, dishwasher, washing machine etc seem to work okay in most installs. I understand the 18th reg about 30% or whatever it is. But I never came accross a problem with it?
Hang on, do some maths and apply brain, domestic cooker hood next to zip load put 20 A DP switch in the grid, either use the fuse module to put the fuse next to the switcch and run 1mm t+E to an outlet plate, or run 2.5 t+e to a fused outlet plate job done... The rules are trying to prevent Kw+ point loads!
Hi thanks those two options makes perfect sense from a purely and 100% wiring regs standpoint and I may yet indeed end up doing one of those. In fact I probably will BUT it is sub optimal from the perspective of the overall job.
Why? A larger grid or an extra fcu plus flex outlet is an eye sore. A hidden 13a plug is not although the latter solution is far from being technically elegant.
While I'm here, why do these fans all come with plugs? Maybe there are some that don't?
FCU in nearby wall unit or above worktop , 1mm to hood ,chop plug off , join through with click flo connector .
This is usually the easiest option as most hoods just come with a bare flex these days. A Click plug means anyone can connect it up and no return visit. Either that or I sometimes favour a flex outlet plate if I'm putting the hood up myself.
Reply to Cooker Extractor Plug or not in the UK Electrical Forum area at ElectriciansForums.net
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hi there, wondering if anyone can give me some advice please. In my kitchen I have a cooker switch with a plug socket which I believe is on a...
Good afternoon, Sorry for the long post but can find answers to my questions anywhere. I’m want to replace my old cooker hood for a new one...
