- Reaction score
- 60
Hi all
New build house
Cookers they re supplying dont have room at the backs to allow for the outlet, so for now we are putting 6.0mm out the side cupboard to dual socket then from dual socket to cooker outlet,socket is for plug for gas hob, outlet for cooker
reason for using a dual is for room for the 6.0mm even though we are only using one for the ignition
another problem is we only have a 300mm cupboard for these to go into next to the cooker and its awkward to do
could do with some solutions pls
i have noticed that there is about 12inches of room below the cooker but if we put socket and outlet there the cable for the gas ignition isn't long enough to reach the bottom (was thinking of putting a dual click cooker outlet on its side feeding cooker then socket),gggrrr
any ideas lads
cheers
grand
New build house
any ideas lads
cheers
grand
