It isn't a 'Crabtree setting' , just the manufacturers name happens to be in that location.
Look at my previous post, the cable from the main cooker switch is most likely terminated in an outlet plate behind the current gas cooker and not utilised right now.
The gas cooker electrics are plugged into the 13A socket. The cooker switch is currently unused.
Look behind the gas cooker, or in the cupboard directly below the switch, to see if there is an unused cable outlet plate.
It may be a good idea to look at your consumer unit and see what rating the MCB for the cooker circuit is before investing in an electric cooker.
I've replaced the switch with a new one but the problem remains the same, I turn on the "cooker switch" and the light on the switch indicates that it is on but it isn't transferring any power to my gas cooker
If you replaced the whole cooker switch you presumably believe the 45A wiring to the cooker outlet plate below (behind your cooker) is correctly connected. How do you know that it doesn't work? Had you previously tried connecting your gas cooker (currently on the 13A plug), to the cooker switch outlet below?
From those pics you have power to the cooker with the switch off but none when the switch is on?
Can we assume the plugged in appliance is nothing to do with the cooker or is it because the cooker is off when switched off.
Cooker display is on when the socket is on, and off when the socket is off, so the cooker electrics are clearly plugged into the socket.
Cooker switch does nothing except light its indicator.
Yes initially I didn't spot the socket switch being on and off I was looking at the cooker switch.
So what is the confusion with the cooker switch if the cooker is powered from the socket outlet.
Big question. Where's the cooker low level outlet, if they've used one?
Photo wanted behind the cooker..........
Excuse the mess behind the cooker haha, the left socket is for a hob
That is where the cooker connects, the right side plate. The cooker switch should turn it on and off, plug that plug into the socket and try it.
Nick86,
Nick86,
