Discuss Cordless kettles in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
cliffed
Supporter
anyone had any probs Pat testing the Philips cordless kettles,5 kettles apparently failed the test for earth continuity.They have been tested by someone else,& ive been asked to take a look,they look nearly brand new.
It looks like there are no Earth pin connection on the base,& it certainly fails a normal continuity test.
It's a common problem with some types of kettles trying to get somewhere to test earth continuity.
Yea thanks for that,not been back to job yet,but this is a class 1 item.
On most kettles there's a definite Earth pin,that you can see,but these have not,in my opinion.
On some of them I find if you press the probe hard onto the base it breaks through limescale etc. to test. However on others this doesn't achieve anything as you still aren't coming into contact with the earthed element. I'm afraid there's no easy answer to it IMHO.
Thanks will see how it goes
Reply to Cordless kettles in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hello, I am currently learning and have come across PAT testing an old chandelier. On modern lamps I would use the plug and probe on the...
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
Hi all, Was speaking to a family member recently, he told me his iron recently made a bang and flash as he plugged it in to the socket, and could...
Just interested in peoples thinking on using the neutral through the earthing system like I came across today. I've come across many wrong...
Hi all, For clarity, I'm not a qualified electrician, but have a reasonable amount of experience as I've done plenty of wiring (signed off by a...
