Discuss Could somebody please help me understand this circuit? in the UK Electrical Forum area at ElectriciansForums.net
Could someone please explain to me what this circuit is used for? I believe it is a full wave bridge rectifier but I'm unsure as to what the zener diode is used for in this arrangement?
Thanks in advance
It's a very basic regulated power supply. Full wave bridge rectifier, as you said, to rectify the incoming AC to DC. A capacitor to smooth the output of the rectifier. Then a zener diodes to regulate the output voltage.
The magic words to search for are "shunt regulator".
The 100R resistor controls the current available. Any current not taken by the load will pass through the zener diode - Iz+Il is roughly constant. For a fixed AC voltage, the power dissipated will remain more or less constant - some in the resistor, the rest in either the load or the zener. One of the simplest, and least efficient, voltage regulators.
For which reason it's no longer generally used, and only normally for very low power. It was more common in the days of fully analogue electronics, and before simple, low-cost monolithic regulators and SMPSUs with inherently regulated output were the norm.
One reason I can think of that you may still find it in niche applications - stability and noise. While most stuff is switch mode these days, that brings with it a lot of noise. Analogue series regulators, whether built with discretes or by use of a monolithic chip, typically have some stability limits - though in practice I think they are generally hard to breach with the ones I've used.
So if you have a low power, efficiency isn't an issue, and want low noise, this may still be the best option.
Reply to Could somebody please help me understand this circuit? in the UK Electrical Forum area at ElectriciansForums.net
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
Help please! Got this to use as a doorbell but unsure of specifics and wiring. If someone could maybe help with a diagram/specific parts or even...
I disassembled a Christmas light projector to try and identify the cause of why the images from the projector weren't moving at all, when they...
Hi all, does anybody know the name of this circuit and how it operates and the purpose of each component please? any help is much appreciated...
