Discuss Cowboy electrician in the UK Electrical Forum area at ElectriciansForums.net
Here that left rcd has tripped has he left a fault there.
It's the 32A mcb thats tripped (though I did have to look twice) I guess that's the faulty socket circuit, though I guess the neutral is ok since the RCD still holds :)
rest of the install is class, I'd be proud to put my name (Billy the Kid)to that.
I was called to a house where they said the fuse for the sockets kept blowing.They had kept replacing the fuse until it didn't blow anymore but now the sockets have no power!.
When i arrived to have a look they said another electrician had come out and in order to fix the fault had replaced the consumer unit! The sockets still had no power to them.
Anyway i had a look and found the house to wired in rubber cable.Obviously the blasting had totally destroyed the conductors blowing apart the fault and now was sat there with no power.
I turned my attention to the consumer that the 'electrician'(and i use the term loosely) had fitted.
Heres what i found.
http://i.Upload the image directly to the thread.com/OVG1tOt.jpg
He has used the old cotton covered tails and fed it through an unbushed hole with the red clearly digging into the consumer unit.
Also the main earth cable looked like it was only 2.5mm!
http://i.Upload the image directly to the thread.com/ADKv2od.jpg
No earth bonding to gas or water.
Heres the inside.
http://i.Upload the image directly to the thread.com/ooOlYg2.jpg
Needless to say there was no certificate,no labels,no part 'p' notification etc.
I am gob smacked at the incompetence of this so called electrician.
What do others think?
Class job (NOT) what a lash up
If you hear the customer had an electrician from Facebook you instantly cry a little inside. Very poor job, I've seen worse like but that is impressive how many regs he's managed to break in 1 job.
I've used BG in the past, but not out of choice. Give me a schneider easy9 for domestic any day and I'll be a happy monkey. I'll even wave a tiny German flag while wiring it up!
Reply to Cowboy electrician in the UK Electrical Forum area at ElectriciansForums.net
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
I was asked to see why a set of sockets weren’t working in the house (which appear to be a ring circuit based on breakers) There was no power on...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
