B
BluSparx
I am sick of being called to "faults" after so called sparkies have been in. The latest on is ridiculous
We recently had a cooker socket installed and it keeps buzzing. Gets there to find that the "new cooker socket" was actually a full cooker circuit. Installed using non-harmonised colours in August 2010.
No RCD Protection on circuit - wired into a Wylex rewirable
Neutral not screwed in terminal correctly - cooker outlet box all cracked and taped over with insulation tape.
Opened cooker socket to find completly burnt out live cable coming from fuse box - customer totally unhappy that I disconnected at fusebox and terminated cable 1 metre away from fuse box so couldn't be reconnected.
Apparently the guy charged £200 to install - NO EIC no PART P Notification, and he no longer operates so nothing can be done
How can these people get away with this
Know exactly what you are on about Sparx, I seem to be chasing poor installation jobs by other so called sparkies too!:mad:
People need educated.
I got a load of leaflets delivered to me from the esc and I hand them out whenever I can to try and further our cause. I'm sure they are just binned after I leave though!:rolleyes:
I have now got a load of leaflets too and have started following all my client visits with a letter detailing the work I carried out, what the cause and potential outcome could have been
however I also leaflet drop to 10 houses either side of my customers house and hopefully that will get people talking as they say if you can reach just 10% of these people this will increase peoples knowledge hopefully as people talk and will tell family and friends
How the hell did you get them????? I have been asking them to send me the leaflets for about 18 MONTHS and they never send anything!!!!
Have you any proof it was an electrician who did the work and not a DIY bodge up?
pikeys. seen she's already had her drive and guttering done, so they decided to diveraify
Here is the damage
nothing wrong with that!! :)
check out what i found at that PIR i went too after you changed the cooker cable for rats damage!!!
place must be what 4 years old?? and its been cowboy as well!! FFS at least use Brown!
i dont have any red black cable unfortunately!! otherwise maybe! the IP rating is a bit dodgy like on the back box!
Because home owners want cheap. Even business these days.
This is unfortunately why a gas safe like enrolment should be introduced, which would then be forced down potential clients throats.
