- Reaction score
- 25,531
That is unbelievable.
Discuss Cpc connection wylex in the UK Electrical Forum area at ElectriciansForums.net
Well it will solve the problem but they cost about £5 eachThat is unbelievable.
Yes Matt you are right it does take 3x 16mm2It doesn't, it takes 3x 16mm2.
That said, 25mm2 would be better, for when you run 25mm2 SWA.
Surprising, it does not look big enough for that.Yes Matt you are right it does take 3x 16mm2
So that three way terminal on the back box takes 3 × 16.0?Yes Matt you are right it does take 3x 16mm2
I haven’t tried yet but I have been told they areSo that three way terminal on the back box takes 3 × 16.0?
Reply to Cpc connection wylex in the UK Electrical Forum area at ElectriciansForums.net
