Discuss Crabtree loadstar suitible as a domestic CU replacement in the UK Electrical Forum area at ElectriciansForums.net
UKMeterman
I have a job which is needing a new CU. What would the general view about a new Crabtree loadstar SPN 125A board being used as a domestic consumer unit. I know it will work, I was just wondering about the inspection and how some may argue it some how not right.
Presumably with the matching RCBOs as I guess there is no dual-RCD style of configuration?
I don't see any problem but then I guess the nagging doubt is if Crabtree certify it as a "consumer unit" rather than a generic DB to BS EN 61439-3
Out of curiosity, any special reason to chose that board?
Why dont you think it would be acceptable?
Reply to Crabtree loadstar suitible as a domestic CU replacement in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I needed to replace an MCB for an electric shower with a different rating, it's an older Loadstar consumer unit, and crabtree told me word...
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
Morning guys! Went to look at a consumer unit change today with a PME supply. Now, right next to this was an old BS3036 60A fused mem cutout...
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
