M
midgetman
Hey midgetman here
Extending twin and earth 2.5mm ring to take in two more sockets. Just looping down to them and then back to the ring.
Using blue and red crimps and some heat shrink. my mate says as they is in enclosed in false ceiling under floor boards this joint even though it is crimped and heat shrunk must be put in a choc box or similar so its in an enclosure. Is he right or is he just having a laugh?
thanks
try the Hager maintanance free junction boxes, it may cost you a little nore than your previous plan but will take half the time and within the regs
ok nice one - I will have to see what depth they are as I only have very limited space.
think if you heat shrink a sleeve over the whole cable, thus making it double insulated, that would comply.
I think the issue is ensuring there is adequate strain relief for the joint. I suppose clipping it to a joist would suffice but a choc box is just as quick if not quicker due to not having to get out and set up a heat gun/blow torch. I've only ever used crimps and heat shrink for extending cables buried in walls. Not much chance of them being tugged when they're surrounded by render and the glue filled heat shrink ensures moisture won't get in.
My understanding also as you are basically replicating what was there previously and crimps are a maintenance free joint :thumbsup
Quite right guys that would IMO comply with Reg 526.1
But the reg in my post is
Every termination and Joint in a LIVE conductor or a PEN conductor shall be made within one of the following or combination thereof:
(i) A suitable accessory complying with the appropriate standard
(ii) An equipment enclosure complying with the appropriate product standard
(iii) An enclosure partially formed or completed with building material which is non-combustible when tested to BS 476-4 (This as in Dunc post)
oh oh i guess the min requirements then is just heat shrink. That's cool cos my mate bet me a bluey on this. He reckoned it had to be in an enclosure i said as long as the right size crimps were used and proper heat shrink that would suffice. This is good news actually guys cos i only got 25mm space .
I must add bit like that as long as it is properly clipped as well.
So that was a waste of time posting that then
To be honest with you I cannot stand crimps. I have had occasions when using crimps and ratchet crimp tool where the cable has still come out of the joint with ease. I have since stopped using the ratchet tool and now use my snips (the type that come with the strip, crimp and threaded screw cutter). I have found these far more reliable.
I would also recommend the use of an enclosure wherever possible because if for any reason anyone does tug on the cable it could easily break the ring continuity on one if not all of the conductors and would go un-noticed unless an electrician had reason to be testing that circuit afterwards:goofy::p:rolleyes4::nonod:
thru' crimps were originally designed for stranded cable and are generally fine with that. typical case of when we had the best cable going, some pratt decides to convert the industry to solid crap ( i'm referring to T/E as opposed to singles ). if you've ever tried pulling in 2.5mm that's been on the van overnight in january, that's one reason for calling it crap.
You have just got to be kidding us here?? What you need is a decent crimping tool, one with adjustable crimping pressure. There is No Way on this earth that those cheap combi crimp tools can better a pukka ratchet crimp tool. Except maybe as in your case, ...a worn out ratchet crimp tool!! lol!!!
Having spent many unhappy hours chasing fault due to crimps being used on solid conductors I’m against them 100%. As designed for use on stranded they are great and I trust them.
I've used through crimps for years, it's like any jointing method...a poor tradesman can make a poor job of anything be it an swa gland or a resin pot. It comes down to the proficiency of the OP. For me crimps are a reliable jointing method. Some guys here don't like wagos but if you shove 'em in properly you simply cannot pull 'em out.
OK, two observations.
One :: Some through crimps are carp. Called CK as the blues and reds bought from Electrifix were not holding on any pressure. CK tech said oh yes we have had complaints about them, you want branded SWA ones. So swapped and works fine.(Threw the old ones in the van - mistake I then had 200 of the little blighters in the door runners :) )
Two :: Even better solution - I misplaced my CK ratchets so bought SWA ratchet crimpers. Look the same without the numbers on the press. They were £10 less than my CK yet work with their own SWA crimps even better! It's not the adjustment either. Later in the week I found the CK ratchet crimpers and when you compare the two the head is the correct length for each part of the crimp on the SWA ones. Moral - use crimps and ratchet from same manufacturer IMO.
Have to disagree with you on that one Tony, a decent crimp tool with decent crimps and you will have a permanent joint that isn't going to go anywhere fast!! Always use a crimping tool that deforms the conductor within the crimp, that is the determining factor with solid core crimping!!! It's all down to that age old saying, using the ''Right Tool'' and Right Material'' will win the day every time...lol!!!
I've had crimps from a few places but ERF do solid crimps which take two hands (and I'm 6'4" with big arms) and I've NEVER had one come off. as DaveyB says, you need to make sure you use quality components and tools. If you're doing that, there's no reason you should have any issue.
beat me to it Eng54!
Um??? Nope lol I place more faith in my snips than I do in the ratchet tool that I have been currently using.
A valid suggestion and I would quite happily part with whatever the cost of a new ratchet tool providing I know it's going to do it's job correctly:thumbsup
Trust me, I have more confidence in my snips which is why I use them. I did several test runs using them and they never failed even after a short sharp tug :)
can.jpgif only carlsberg made crimps.
I'm lucky enough to have a set of AMP crimping tools. Three separate tools: red, blue and black/yellow.
I also have a CTT ratchet crimping tool with a red/blue/yellow combi die set and a 10mmsq die set
They wouldn't let me have the BICC G10TS though lol
Whenever I have to make crimped connections I use decent AMP crimps - I find that most others don't have enough "meat" in the barrel that crimps onto the conductor - usually just the same flimsy tinned copper sheet that the crimp's tongue is stamped out of.
However I have found budget crimps on occasion that do have a strong barrel and perform well.
The AMP tools form the insulation grip differently - a rounded diamond shape - and this makes the crimped connection more tolerant of vibration.
However in my previous job, it was forbidden to use crimps on solid conductors.
Simon.
well tel you should never pull you cable in january , wait till tempertaure is up and then pull, far easier
crimp and shrink
Australia
midgetman,
1shortcircuit,
