Discuss CU prior to garage conversion in the UK Electrical Forum area at ElectriciansForums.net
guediver
To be clear: I will have a qualified electrician doing work for me and I have discussed this with them. I am looking for general advice to help my planning
I’m having a new CU installed prior to a garage conversion (conversion to be done by me). Current CU is on external cavity wall which will be later brought out in stud and insulation.
My dilemma is
1) is it permissible to stud and insulate around a CU if it were now installed on the block work? (I’m aware of access requirements)
2) if not permissible, or just not a good idea, is there anything I could do ahead of the electrician coming (short of building the entire stud wall)?
This feels like a common problem in retrofits/ renovations and wondered what solutions get used. I did speak about this to my electrician when he came to quote but I don’t really remember a clear ‘this is what we’ll do’.
mount The new board on some stud work so it comes out to the same level as the finished wall will be.
If I'm understanding the OP's post correctly, I'd leave the CU exactly where it is and frame out the area around it in the studwork, so that eventually it sits in a recess. If the recess turns out to be deep enough, it can be turned into a cupboard by adding doors and architrave in front of it.
Done this many times, including all three of my holiday cottage conversions..
I've used both of the solutions mentioned above, either bring CU forwards or build a recess for it.
I generally prefer a recess as it makes a future CU change a bit easier.
As noted above Hager make a nice flush mounted CU where the sides are of adjustable depth.
It comes does to what you feel is the most acceptable aesthetic solution.
Reply to CU prior to garage conversion in the UK Electrical Forum area at ElectriciansForums.net
I would like to hide the cable to an EV charger. The consumer unit, meter cabinet and charger would all be on the same wall. About 5 metres from...
Hi. We live in an older house and we are doing a loft conversion. We do not have an SPD on the connection to the grid and the builder's...
5K
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
