Discuss Daft question I'm sure in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
OK here goes...
All the light switches in my house are set at 1450mm or there abouts from finished floor level. If I am redecorating a room and moving a light switch from one side of the door to the other do I have to set it at 1200mm? Making it the only light switch set at the correct height? Or can I just set it 1450mm like the rest?
OK here goes...
The 1200mm is for new buildings. If you are altering an existing circuit then you can keep it as the same height.
You spend waaaay too much time on here mate.... Give us part-timers some chance... :tearsofjoy::tearsofjoy::tearsofjoy::tearsofjoy:
Quick draw Macgrawl is my name, no point in ----- footing around get to the point Mate, if you ain't quick enough Mate, keep out of the kitchen:tongue::raisedhands::thumbsup::coupleheart::mouth::praying::okay::oldwoman:
OK here goes...
Take a look at the pictures, on here, of some of the electrical work that people get paid for. Nothing or anybody ever gets done for it. The 'Authorities' don't give a sh..........
Quick question to piggy back on this...im thinking of extending my place next year. Now as there will be new bedrooms, bigger kitchen new bathroom etc etc electrically would it have to conform to part m or is it possible to have the same heights as the old part of the house
yes it is fine. basically, heights should be similar to existing unless existing heights are stupid.
Reply to Daft question I'm sure in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
