E
electricAl
In addition to my concurrent post regarding large farm install, have to concentrate right now on lighting scheme for the near to completion dairy.
Lighting milking parlours isn`t an area i`ve any expertise in, so suggestions most welcome...
New steel structure 78m x 36m, 9m high apex along longest dimension. 5m height at verges
4.no new Lely robots running out in cross shape from centre - each approx 10m in length. Excepting overhead office, and cleaning equipment etc, remaining area of structure (approx 70% of area) given over to cattle `resting` areas (posssibly not a technical term but you get the picture)
Baseline levels around the robots approx 150lux (24/7 milking operation)
All other areas will only be lit when necessary, & farmer adament 50 lux would be plenty.
Tho plenty of height under apex, will struggle to achieve 6m mounting height out towards eaves, so Hi Bays are marginal (6m about there min recommended mounting height)
First attempt with ReLux came out with 24.no HQI Hi-Bays, 250w each, tho may up those above milking areas to 400w.
Sound reasonable?
Will attempt as best i can to split over the 3 phases, so at best 8 x 250w per x f1.8 ~ 3.6KW per bank so a few contactors aswell as timers (farmers request) mounted with panelboard in office area. Minimal switches at entry only (farmers request again)
Section 705 demands IP44 as bare minimum anywhere on farms, tho makes mention that dairies may well be a more onerous case. Strange that my usual supplier of HiBays said he`s supplied a dozen dairies this year & none had requested specific IP units - IP20 supplied in each case
Am i being too stringent with the regs here - no mention in 705 or GN7 of a relaxation due to 6m mounting height.
As to erection, thinking 6491x singles in hi impact pvc conduit, britclipped to girders, kliks & h07rn-f down jack chain to IP65 fittings. Adaquate protection surely given >6m up in air
Any thoughts...
Sound reasonable?
Am i being too stringent with the regs here - no mention in 705 or GN7 of a relaxation due to 6m mounting height.As to erection, thinking 6491x singles in hi impact pvc conduit, britclipped to girders, kliks & h07rn-f down jack chain to IP65 fittings. Adaquate protection surely given >6m up in air
Any thoughts...
