Discuss dali controller??? in the UK Electrical Forum area at ElectriciansForums.net
i have been asked to dim some led 600x600 panels ,they have a dali 1-10 input but i am unsure of the controller needed.
the only other times ive used dali type dimming was from an area controller in a riser but, seeing as this is a one room jobbie i am unsure of any stand alone kit
Any suggestions??
Not sure if the whole LCM route is needed just want something like a transformer or a balast type jobbie whiich could be mounted in a box of some sort,
Not so sure about their prices but a lot of the cp-electronics stuff we use at work seems to be good. would be interested to know what you end up using sibbits. have fun.
Reply to dali controller??? in the UK Electrical Forum area at ElectriciansForums.net
Evening all, Just a quick question, I am an electrical maintenance engineer and have 18th edition, inspection and testing and so on, so I get...
Hi all, I am currently in the process of quoting a job to renew the mains for 19 flats. This is the first job of this type that I have quoted so...
Good morning all. I have an issue with some dali lighting. Basic system as far as i can tell. Dimmer, controller and 8 button switch. No other...
5K
Hey, with regards to DALI Emergency Lighting Automated testing via a control system, does anyone know how best to overcome a fitting that is...
I am installing some driveway lights. The customer wants to be able to switch them on from t he house, but also have a PIR at the driveway...
