Discuss Difference between Drivers and PSUs?? in the Electricians' Talk area at ElectriciansForums.net
A psu supplies power at a constant voltage with a varied current as required.
A driver supplies a constant current over a select voltage range.
LED`s require a driver to operate correctly.
Thanks Tazz.
I have an old PSU from a PC which I would like to use if possible. Now I know they have multiple 12v outputs, and the consumption needed will be somewhere in the region of 36v (12x 3v LED), is there any way of wiring this PSU to the constant current driver to deliver the 36v?? Ie connect 3 sets of 12v outputs from the PSU to the driver?
Cheers mate.
Thats brill, thanks. Will three yellow 12v from the PSU wires connected together and soldered to the inputs on the driver provide it with 36v or will it just go bang?
The PSU will probably see the separate output connections as a short.
As a suggestion it may be possible to connect diodes across the outputs to solve the problem, but wait to see what others have to say, or put the question to a good PC repair centre, they should know.
Do not connect the yellows together.
As from Baldsparks video link, wire 3 x leds in series, with limit resistor(value dependent on fw current of led) and wire 4 of these in parallel with the yellow & black psu cables.
One other thought, it may be worth using a volt meter across two of the 12v outputs and see if you actually get an increase in voltage, ie 24v.
I have a funny feeling that although you may have separate output taps, they are supplied from a common source at the transformer.
Sorry Tazz,
I was typing whilst you posted, question is answered.
Spot on.....last thing we need to know is led spec...3v but need forward current is it 30mA....we can then tell you resistor required
They are quite high powered LEDs by cree.
http://www.ledgroupbuy.com/cree-xm-l-white/
wattage:
2.1w (700mA), 3.1w (1,000mA), 5w (1,500mA)
max drive current:
1500mA
forward voltage:
3.0v (700mA), 3.15v (1,000mA), 3.3v (1,500mA)
luminous flux (cool white):
244lm (700mA), 327lm (1,000mA), 424lm (1,500mA)
There will be various colours but I'm guessing I can do the same thing with other 12v yellow wires from the PSU and just have several loops?
if 1 LED went open circuit, the other 2 in series with it would go off.
Reply to Difference between Drivers and PSUs?? in the Electricians' Talk area at ElectriciansForums.net
Hello ! I am building for some time a cct to drive a 3digit multiplexed LCD. (from aliexpress) From the sellers on aliexpress I managed to find...
Newbie alert! I have this lovely aluminium outdoor lamp (parts are milled from a solid aluminium billet), but the IP44 rating did not cut it with...
Hi all, first post so be gentle... I've recently decided to replace the MR16 50W Halogen bulbs in the bathroom with 5W LED ones. I'm aware of the...
Hello, I desire to power (4) 300W LED COBs simultaneously via a single 120v AC plug. Each COB has their own 300W driver. The driver is AC input...
Hello folks, hoping for some help on a project I'm doing at home involving my 3D Printer (...it's 2019... who doesn't have one of these things at...
