Not sure what you mean DefyG?If its doesn't comply with the regs!
Yes I would worry. Irrespective of whether a single or upgraded to a three phase supply, the installation should still comply with the regs!Would you worry about the rings are on different phases & close to each other.
Regulation number?Socket outlets simultaneously accessible when on different phases?
When the OP says different rings, I'm assuming he is referring to the socket outlets.
If he is referring to the actual cabling then maybe no problem.
I also am interested in why you think this does not comply to regulations, there is no issue at all here and if I recall there was once a regulation which called for them to be marked with a caution label if within arms reach of each other but I don't believe that exists anymore.Socket outlets simultaneously accessible when on different phases?
