Discuss Dimming xmas lights! in the Canada area at ElectriciansForums.net
R
Rob
Hi my question is - i have some 240v 227w cascade xmas lights. i have 3 of these sets in wired in series. I want to dim them so a normal light dimmer would do the trick for 1 set but because there are 3 sets - do i have to find a dimmer capable of 681w?
If you connect the sets in series the voltage will be reduced and the lamps will be dimmer anyway? Remember your series and parellel circuits? If you wire them in parallel then yes would be the answer to your question. Why are you dimming them? (hope you don't think i am being too nosey)
series or parellel he will still need a dimmer switch capable of 681w i only know of 400w dimmer switchs, thats the most i have ever installed. so good luck finding one rated at over 600w lol. if you ask me its prob not worth the hassel.
They are in a pub on the ceiling and they are too bright! they haven't dimmed much!!
G A Electrical do 1000w dimmers!
Reply to Dimming xmas lights! in the Canada area at ElectriciansForums.net
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Kitchen led lights have all of a sudden dimmed by about 30% no dimmer in the system. There are 2 switches for this set of lights. Regardless of...
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
Hi All, Pretty comfortable with wiring lighting until I came across needing to install 2 way dimming with a Retractive switch. I didn’t even know...
