Hi, Came across this the other day when looking to quote for a CU change. I can't figure out how the installation is earthed. There is bonding to the water pipe. I didn't take the cover off the existing CU as it wasn't practical when I visited. Measured a Zs of 0.3 from a socket. Its a terrace house, so wouldn't think its a TT. Does anyone have any thoughts?
No sign of an earth rod. You may be onto something regarding water pipe and next door.
Think I'll go back and take the cover off the existing CU, disconnect the bonding and test Ze to see what I get
be careful if you have quoted for a visit by the seal fairy on this job... I saw one of these once and the DNO were upgrading the cut out anyway, but they said just as well as were they going to pull the fuse they would have refused due to something amiss inside. The fuse looked like it had degraded around the ends and almost become joined to the holder.they would have cut the wires outside hot and rejoined afterwards.
May be a tncs, have you got a pic of cu with cover off? If you took it off?but get the customer to phone up supplier and request a new head (a little exageration say its cracked ) will get it changed pronto for you cu change.
Firstly as I said it wasn't convenient to take the cover off and secondary, I don't see why its necessary. Do you always take the cover off when quoting for a Cu change? Apart from maybe all the circuits with fuses/MCBs may not be connected. Please do enlighten me?
you take the cover off to do some basic testing , mainly to ensure that you won't get anty poor IR readings /OC rings/ etc. which would entail additional costs. then you quote accordingly, knowing what extra work may be involved.
That's what I quote, CU replacement + any faults found whilst testing will be carried out at an additional cost.
I'm not going to carry out any tests without being paid for it. I may advise testing be carried out before and provide a separate quote for that.
Woking
Distributors earthing?
Grayza,
paleosparky13,
