Discuss Diversity Factor for 3Ph instantaneous Hot Water in AS3000 in the Australia area at ElectriciansForums.net
Hi,
Just a question from AS3000 max demand diversity table C1 for instantaneous hot water. Will it be the same diversity regardless if it is 3Ph or 1Ph or higher current rating or less?
Same diversity factor (0.33x), just keep in mind this is for consumer mains/submains max demand calculations, the cable and protection should be sized for the full draw of the heater.
Reply to Diversity Factor for 3Ph instantaneous Hot Water in AS3000 in the Australia area at ElectriciansForums.net
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
  • Locked
5K
Hi folks. I'm asking so that I can do some planning, and then hire a local electrician to do the work. WHAT: This is my first question, ever...
I have a 230 Volt single-phase circuit with a 100 Amp cutout fuse and a 100 Amp MCB switch, so the supply is rated at 23 kVA. Only about 13% of...
6K
