Discuss DIY - Can I run a fridge-freezer and a freezer from one socket/outlet? in the DIY Electrical Advice area at ElectriciansForums.net
A friend who's moving has offered me her upright freezer and I'd love to have it. However, I already have a fridge-freezer and I'm a bit worried about plugging them both into the same power point. I've read online that using both at the same time could blow the circuitry. My Proline fridge-freezer is about 10 years old and the new freezer (a Beko FFG1545W) was bought a few months ago. I've included what info on the products that I've got (I won't be able to get more on the Beko from my friend for at least a week) - being new to DIY and newer to electrical stuff, I don't know how to work out the amps from this.
Would I be OK to use them with a 13amp double-socket adaptor (the cube-shaped type) or should I get the socket rewired to have two independent sockets? If rewiring is needed, some idea of the cost involved would be appreciated. I'm in the UK. Thanks.
You'll be fine using both from one socket, but don't use the cube type adaptors - use a decent quality 2 way or 4 way trailing extension.
Reply to DIY - Can I run a fridge-freezer and a freezer from one socket/outlet? in the DIY Electrical Advice area at ElectriciansForums.net
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
A few weeks ago I posted this in another thread...: The tripping kept occurring, so I went back and moved a likely candidate circuit to the...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Hi All, This might be a bit of an odd question, I would really appreciate your thoughts. I am trying to up-date my mum's home, before putting it...
