Secondly from an electrical point of view is there an argument for legislating that the complete domestic electrical installation is protected by 30mA RCCD...no exceptions? There's no guarantee that it would have saved this person's life but it might give a statistically higher chance of survival in this kind of circumstances.
I would be all for a recognised loophole for domestic installations to be fitted with RCD protection before any additional work is carried out. Most customers will not stump up for a 17th eddition board, but may go for a single stand alone RCD as a retrofit, providing they know that it would take out the entire installation if a fault occured. Although not compliant with the regs, I would happily enter this as a deviation on a cert, knowing the WHOLE installation is that bit safer, and something like this may have saved this mans life.
At the end of the day, the BRB is just a set of guidelines that can be bent/broken, as long as you can justify what you have done AND leave the installation in a comparitive or better condition than found.
Re reading my earlier posts i i realize i failed to show the due sympathy and the admiration to yourself for carrying out such a unsettling task , and i do apologies for that wire puller .
If this is still sitting as uneasy with yourself as you mentioned earlier , may i suggest it would by no way mean you are a lesser man if you were to seek some counseling maybe ? And i think it will help immensely , if you need any info on where to go , one of our past employees was a fully trained counselor and could probably be able to let you know where to find some one local to yourself .
Just pm me if you wish .
All the best
