Discuss Do "holes" stay put while electrons move? in the Electrical Engineering Chat area at ElectriciansForums.net
salt water conducts with a positive charge and a negative charge moving in different directions. Is this different than a single electron moving through copper and the "hole" staying still? I see a lot of contradicting models.
thatll teach me to be a smart arse.
so electrons do move?
I guess if its a circuit... a circular path, then the initial hole will be filled by the first electron that was pushed out of its hole by the one behind
equal number of holes vs electrons... or there should never be a hole... as there is always an electron to fill it
my head hurts
To answer the original question, salt water "conducts" electricity in a completely different way to current flow in a conductor. Maybe better to think of it as 'electrolysis'.
This explains better than I can:
Salt water consists (mostly) of H20 molecules, Na+ ions and Cl- ions. When two electrodes are put in such a fluid with some potential difference the Na+ ions will be attracted by the negative electrode and will move (somewhat more) to that electrode. Likewise for the Cl- ions and the positive electrode.
When the voltage (potential difference) is large enough the Cl- ions at the positive electrode will give an electron to the electrode, and recombine to Cl2 molecules (or react with the electrode). You will be able to see and/or smell this. The situation at the negative side is more complex, but at that side the net result will be that the Na+ will help the H20 to get converted to H2 and OH-. You will see bubbles of H2 gas here.
The net effect is that NaCl and water become Cl2 gas and H2 gas. This is a chemical reaction. It is quite different from normal electron conduction.
Reply to Do "holes" stay put while electrons move? in the Electrical Engineering Chat area at ElectriciansForums.net
Once again I am using the Engineering chat as I think my question is more theoretical rather than 'diy advice'. If I am misusing the forum...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
Last weekend I experienced a weird electrical fault with my 2010 Peugeot Boxer Van. A little background - the van is a 2010 Boxer 330 2.2 Short...
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
