Superspark23
For the FP200 co2 dectector circuit, does the fp200 need to be seperated from the mains? I remember installing some on site once and it had to be segregated then and i was going to install it like that today. then noticed the dado trunking didnthave any holes to the fuseboard in the bottem or top section
AND for the motor circuit how do you set the overload? never worked with motors or anything so not sure and never heard of anything like this need doing in the past! wish i had.
Hi my names Phil,
Was wandering how your am2 went ?
i have mine in a week and was wandering if you could give me any advice ?
how strict are they ?
do you test zs or do they expect you to use the equation instead as ive been told different things
Thanks Phil
You're nearly a year late....
[automerge]1583080938[/automerge]
Hi, what excatly is a conduit bridge? I have AM2 coming up and would like too see a photo of one. Or is it simply a short section of 20mm PVC conduit that you push in?
…..and you're about 9 years....probably out of the country, by now..:(
Yes it is just a short piece of 20mm pvc conduit to act as a shield as its passing through the power section
It's a small section of plastic containment that allows you to take the data cable up through the power cable compartment, providing protection from interference. I can't remember exactly what it was tho as I done mine a few years ago, but it's something like a bit of trunking or conduit yes.
