they could replace all them nasty double yellow lines with copper strips. tap off the supply to properties with an earth rod banged in by the kerb. trolley buses could then be re-introduced with swingin pick-up arms to run along the strips, instead of those unsightly overhead cables.
Anything to get rid of double yellows!
Think it’s only used for ELV in the U.K., speaker wire and such.
I believe in the US that it can be used for 110V?
what a bad idea, ive seen wet plaster walls that have become live due to leaking into a live socket, not 230v but still enough to give you a tingle
Yes, and if it over heats you will have scorch marks on the wall paper!
i heard somewhere that a product will only be recalled if enough complaints are raised against it, like with those "hover" boards that were always catching fire when charging
from what i recall the producer can stick their labels on it as a "pass" and its not until it reaches the end user where it is actually tested
surprised if any spark worth their salt uses this tape ---- though!
The video finished before the 'Now lets see if it works" moment. I wonder what happened?
Maybe he realised that the 90 degree fold-over corners he made was copper to copper.
Deleted member 26818,
Adam W,
