R
rihill
My 27 year old doorbell started to hum & buzz all the time. Replaced it & the push button and the doorbell still hums & buzzes. Replaced the transformer and the doorbell still hums & buzzes. What else could it be?
No, there's no wasps in any of the boxes.wasps in the enclosure/s?
Yes, there's a rubber washer on the connection under the transformer.have you tried rubber washers under the transformer?
It's not ringing and the buzzing is definitely annoying.Is that Hums and Buzzes instead of ringing?
Or does it hum and buzz as well as ringing and it's the buzzing that's annoying?
Lamination Hum 1 1 1 1It's not ringing and the buzzing is definitely annoying.
Even without the push button being wired & connected the doorbell still buzzes.Lamination Hum 1 1 1 1
It buzzes even if the push button isn't hooked up.the humming will be from the transformer ,end.or Wire stripper. Doorbell button. A humming doorbell is a common problem that is easy to fix. Since the button is used so often, it can get damaged or partially stuck in the contact position. The humming is usually caused by the button being stuck in the contact position.
Whether or not the push button is wired, the doorbell buzzes when the power is turned on.So if you dis the lot is the humming still there if its not that must be some thing else.
